Inventor General
Distinguished Contributor
Message 1 of 8 (249 Views)
Linking Drawing Dimensions to a Table
249 Views, 7 Replies
04-25-2012 01:02 PM
Is it possible to link the dimensions in my .idw to the table in the upper left corner?  I want the information in the table to reflect what is in the drawing.
I'm using Inventor 2012
Thanks!
Steve
Steve Frey
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Valued Mentor
Message 2 of 8 (222 Views)
Re: Linking Drawing Dimensions to a Table
04-25-2012 05:52 PM in reply to: SteveFrey
Hi Steve
I think you would have to convert your model into iPart. Then the dimensions will be available to populate the table.
Igor.
Web: www.meqc.com.au
Message 3 of 8 (206 Views)
04-26-2012 06:14 AM in reply to: IgorMir
I'm not sure I understand.  Why would converting it to an i-part be any different?  Don't the dimension properties still reside in the file?
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
sam_m
Message 4 of 8 (203 Views)
04-26-2012 06:24 AM in reply to: SteveFrey
Sadly don't know a way to insert model parameters into a table but you can do it with a text annotation:
"Unit Height:  Model Parameter d0
Unit Width: Model Parameter d1" etc
Using the bottom row of drop-downs in the text editor dialog box...
Arguably not as neat as a table, but could draw a text box around it all...
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Message 5 of 8 (184 Views)
04-26-2012 12:08 PM in reply to: sam_m
Sam:
Could you send me a screen shot of where to enter this?  Thanks.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
Curtis_Waguespack
Message 6 of 8 (178 Views)
04-26-2012 12:17 PM in reply to: SteveFrey
Hi SteveFrey,
It looks to me as if this is an assembly. Are the dimensions you want in the table available as assembly parameters?
If so you could check the Export box in the parameters dialog box and then they will be available as Custom iProperties. Then you could use a Parts list as the table and pull that information in. I'd consider making all of the information in that table custom iProperties also, just so that becomes container for all of the info.
Now if those dimensions you want to pull into the assembly do not exist in the assembly, you might need to go to the Parameters dialog box and use the Link button, and then Link to the part files and import the parameters.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 7 of 8 (173 Views)
04-26-2012 12:32 PM in reply to: Curtis_Waguespack
Okay.  I will fool around with it and see how it goes.  Thanks again.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
Message 8 of 8 (155 Views)
04-26-2012 03:31 PM in reply to: SteveFrey
Oy! I got partway through but I'm having trouble. I've exported the assemby parameters but now I'm having trouble linking them. Some "training wheels" please. Thanks.
Steve
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
