The small cylinder was made first, then projected it to a sketch, made offset, and made the big cylinder, but i want to leave only the big cylinder alone. i want to suppress the small cylinder, but when i suppress the samll one both get suppressed.
How can i break this link, which was made by the projected geometry?
Even when i select the projected circle, right click and select Break Link, they still behave the same
If you do the second Extrusion as a New Solid, then you can turn off the Visibility of Solid1.
You must become very familiar with child/parent relationships (or switch to Fusion 360).
