Solved by yannicknielsen. Go to Solution.
Dear Sir / Madam,
Thank you very much for your help. I have started using dwg file in to inventor .
But Inventor running very slow in dwg than idw. Is there any setting for the same.
pls help.
Thanks in adavance.
Dattatray Indalkar
Names from different countries can be hard to tell the gender of. I happen to be male, so it would be sir 😉
I haven't experienced my inventor becoming slow because of that.
You can try a few settings, either under "Hardware" tab, or "Drawing" tab.
I'll upload a file with a setting you can try and change as well
Dear Mr.. yannicknielsen,
Apoligize for not calling you with proper name.
Your suggested option is not with my inventor ( inventor professional 2011)
file contains some autocad blocks. Is it happen because of autocad blocks? File size has become 31 MB.
As opened the file memory shows yellow indicator & As soon as placed two or more views in the sheet it turns to red low memory.
For more clarification PFA file on which I am working.
Pls help me to get rid of this problem.
Datta Indalkar
