I was just wandering if there is any possible way to get the DWG NO. (part name in our case) to link the the Sheet Name in the Browser window? Any help would be appreciated.
Regards
Andrew
Solved by Dennis_Jeffrey. Go to Solution.
Only by renaming it. Rename the first sheet, All others created after that will follow that convention
Thanks Dennis. I had kind of thought that was the only way but wasn't sure. Thanks again.
