I am troubleshooting inventor and I can't figure out what happened.
For example, if I make a triangle in sketch mode and I change one of the
line dimension, the rest of the lines do not follow the shape. the green snap dot is missing.
I repaired Inventor in the control panel with no result.
Do I have to reistall the whole program?
Thank you
Dino
you should state your version of Inventor in the future, but having said that I can't open your file with 2010, so I assume you're using 2011.
try this, right-click while editing a sketch:
you might also need to check these options (they might be in a different location than shown on your system. click the little black arrow shown here if you don't see those buttons):
