Anyone got any ideas on the following? This is happening on both 2012 and 2014, the workflow was what I followed offline to try and replicate an issue on a live project:
I then get an error saying the sketch does not contain a valid section line and the section disappears
My section then reappears
My section remains. We're experiencing a lot of problems of section lines and therefore sections disappearing even though we're not directly applying fix constraints, I was wandering if Inventor applies a fix constraint should geometry that a section line is constrained to disappears.
Regards
Chris
Chris,
I am using 2012 and can't say as I have ever experienced that. I don't ever place a fixed constraint on my sections and don't have any issues. Any particular reason for the fixed constraints?
My other thought is are you running the latest SP's and updates?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi!
I experienced the same in 2014.
I think you found a bug... report it!!! well done...
Regards.
Can you post some files in 2012 exhibiting this behavior?
Many thanks for you to report this issue to us! And it has been tracked in our system as 1505303.
2012 Files as requested. Open the .dwg, edit the sketch and apply a fix constraint to the line itself, finish the sketch and hopefully you'll get an error and the section disappears. Edit the sketch, select the line, RMB, remove the fix constraint, finish the sketch and it comes back.
Regards
Chris
Chris,
That is truly bizzare!!! Happened just like you said.
Like I said I have never used a fixed constraint on the section line, but obviously that should not happen.
Based on the response from Autodesk it would appear that this is being investigated.
I guess the moral of the story for now is don't apply a fixed constraint to your section sketch line.
