Inventor Forum
Line visibility in IDW
2 REPLIES 2
RogerTheShrubber
681 Views, 2 Replies
Using Inventor 2013.  In an IDW, I have toddled off visibility of lines in a view.  I would like to regain visibility of these lines.  HOW?
2 REPLIES 2
Hi messt14,
Here's a link with some screen shots that provide the answer to your question:
http://forums.autodesk.com/t5/Autodesk-Inventor/Turning-on-Visibility-of-Line-Segments-in-Drawings/m...
I hope this helps.
Curtis
Cadmanto
in reply to: RogerTheShrubber
If you RC on the view with the lines that have the visibility turned off you will see this selection.
Then select the lines you want to bring back and RC again and select "Done".
Best Regards,
Scott McFadden
(Colossians 3:23-25)
