Using Inventor 2013. In an IDW, I have toddled off visibility of lines in a view. I would like to regain visibility of these lines. HOW?
Solved by Curtis_Waguespack. Go to Solution.
Hi messt14,
Here's a link with some screen shots that provide the answer to your question:
I hope this helps.
Curtis
If you RC on the view with the lines that have the visibility turned off you will see this selection.
Then select the lines you want to bring back and RC again and select "Done".
