How can I change the line colors in my dwg files from white to black in Inventor 2012?
Solved by Daren.Lawrence. Go to Solution.
You'd change this on your template (or push to your styles library if you use that approach) using the styles editor>Layers as shown in the attached image. If the sheet background is black or a darker color, the default is going to be white and if the sheet color is white or a light color, the default is going to be black.
Please mark as solved if this answers your question or provide an image/more information if you need further help. Thank you.
Thanks!!
im a beginner, and I found that while Im drawing in my .ipt file the sketch shos blue and green lines, why is that, and also when I print them they are darker than the others, could you help me please?
I recommend that you go through the Tutorials.
Lighter color is unconstrained, darker is constrained.
