I am trying to limit the movement of the subassembly called Intermediate Shelf in the main assembly. If you open the Rack Frame Assembly you will see the top shelf rotates 360 degrees, I want to limit that to 45 degrees from its current position. Any help would be appreciated 🙂
Solved by Curtis_Waguespack. Go to Solution.
Hi matt.johnson35,
I didn't look at your assembly, but I think what you're wanting is calle Constraint Limits. There's a short how to video at this link:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-EBD2C784-0E71-452A-B5F2-22738D22D45A
I hope this helps.
Curtis
Sounds like you just need to expand the constraint dialog. See attached.
