"Confused ... you will be" intro to Soap (the only decent soap opera on TV)
Are you talking about the Library paths to files in the Project file ?
or
The Library parts found underneath MODEL in the title bar of the browser of an
assembly ?
Inv7 won't let you alter files that are in the 'library path' in the project
file.
Either move the file to a different location using WinExplorer, modify and
return
or
Creat a new project file with the files that are under the library path moved to
Local Files path. Then swap between project files.
Duncan
"jaymus" wrote in message
news:f1a5c4a.-1@WebX.maYIadrTaRb...
I recently installed INV7, up from 5.3 and am having difficulty dealing with the
library. ie. creating new parts & assy then putting them into the library. if an
assy is created outside the library, then save as to the library, then move
parts for the assy to lib, then delete parts outside of library. open assy in
lib, tell it where the parts are located, then save(can't do that). not to take
up too much time, where can I find info on this
thanks jaymus
