When I try to run a task with the Autodesk Task scheduler, I am given the warning "One or more library paths are not properly configured. Use the Map Folders command in Inventor to correct this".
I can choose OK to close this dialog and the task seems to run alright. In the project that this task is using, there are not any Libraries defined.
Do I need to try to correct this or is it OK to run it with this message?
