Inventor General
Active Member
Message 1 of 6 (337 Views)
Accepted Solution
Let a wheel roll in a randomly shaped rail
337 Views, 5 Replies
10-24-2012 09:31 AM
As you can see in the attachment (which is a small test version of my full project) do I have a problem..
The wheels on the side need to roll inside the guide rail. I can let them roll in each part separately but not in the entire rail.
I already tried with transitional constrains but then inventor says that there are some problems.
My project needs to become a sectional gate so there's going te be lots more than just 2 wheels in it...
Hope someone can explane me how to constrain this movement
Valued Mentor
mpatchus
Message 2 of 6 (334 Views)
Re: Let a wheel roll in a randomly shaped rail
10-24-2012 09:38 AM in reply to: kenevens93
Try creating a continuous surface (as a seperate part) on the inside of the guide rails.
Constrain the wheels to this surface instead of the rails.
Turn the visibilty of the surface off as needed.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
*Expert Elite*
mrattray
Message 3 of 6 (330 Views)
10-24-2012 09:40 AM in reply to: kenevens93
Don't double post. It's bad karma..
hhttp://forums.autodesk.com/t5/Autodesk-Inventor/Constraining-to-a-random-path/td-p/3669326
Mike (not Matt) Rattray
Active Member
Message 4 of 6 (326 Views)
10-24-2012 09:44 AM in reply to: kenevens93
I'm sorry but it did help... He gave me a good tip which i didn't get on the other post...
Mpatchus: The rail is made by sweeping along a continous axis but in the assembly it always gets divided.. How can i make a continuous surface that wont divided in the assembly?
Employee
Message 5 of 6 (275 Views)
10-26-2012 01:22 AM in reply to: kenevens93
Well, I guss you want to get  a animation, I prefer to use Inventor Dynamic Simulation to get such kind movement.
You can leverage the joint (sliding:Curve & Point), attached please fiind the iam file , I made some changes on your dataset, simpliified the assembly  and modified the guiderail part,  since it requires a close loop.
Inventor Professional 2013
Inventor Professional 2014
Jingyi Liu
Quality Assurance Team
Employee
Message 6 of 6 (270 Views)
10-26-2012 01:25 AM in reply to: kenevens93
Also modified attached part to create a sketch point.
Jingyi Liu
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
