OK,... I came across an issue while looking into a possible solution to another question posted here:
In an attempt to change the unit display on a CC item (from decimal inches to fractional), I came across what, to me, is an issue. In the CC I set the length on a pipe conduit part to a custom column, with the range at .001 - 240 inches. I modified my filename column so it was a string that included the length value at the end. (ie Spool x length).
If I place from CC, as custom, a piece of this conduit, the filename does exactly what I expected. If I specify 24 in the length box in the CC dialog, my filename comes in as "spool x 24"... (or to that effect, I'm paraphrasing). If I do the same thing within the context of a pipe run in that same assembly... the filename, even though I chose place from CC, as custom, and specified a length, comes in as "spool x .001". Every time. And also, any spool pieces generated as a result of populating a route. I expect the filename there to be different as tube & pipe has it's own rules for naming spools... but the description field still generates as "spool x .001".
So, it would appear that the column parameters set in the CC, do not apply at all in Routed Systems? I may have to put this in the idea station... wish I had found it last year, now I'll have to wait another year for apotential fix.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
Chris,
If I understand your issue correctly, you are expecting the length to come in the description as per the specified length when placing the part? Is that correct? If so I have done this with my unistrut structural pieces. Which is what led to my idea (which might get lumped into yours or vise versa) and caused me to start my other thread.
I do have what I have done documented if it helps you. Let me know if you want to see it.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Scott, thanks, I have gotten this to work in Frame Generator... but not Routed Systems. Following the same procedures. My frame lengths all show up in my BOM perfectly... in piping, I have to manually edit them. This is a real pain, especially if you change something and forget to update the BOM.
I'm going to keep messing with it, but I think I'm at a dead end. If and when I post the idea, I'll put the link here.
Chris Benner
Long winded Idea Station post for this. Sorry, interesting day so far.
Chris Benner
Chris,
I got it and voted for it.
Mine are setup for both regular insurtion and to work through the frame generator. Both display as I would expect (with the exception of what I want in the other thread and can't have ).
I guess we will both see where this goes.
I just discovered how to get it to do what you want for description and part number but not filename.
After you create your route, right click on the hose/tube and "change size". Just don't change the size and click "OK".
You will have your partnumber and description populate with length exactly the way you want.
The filename is another issue.
WARNING!! DO NOT CHANGE LENGTH WHEN YOU CLICK CHANGE SIZE!! YOU WILL NOT GET THE ORIGINAL LENGTH BACK WITHOUT RE-ROUTING THE HOSE/TUBE!!
