Did you ever figure this out? I'm coming from SolidWorks and am very fustrated that I can't figure out how to do this.
I just answer this a on a diferent post but i hope this helps.
I have a work around that works. It not worth the time to do it every time but would work well with a template. You would have to make an iLogic rule on the drawing level that makes a custom property change to match the subassembly decryption. Then you can pick the custom drawing properties to pick the decryption. This way everything will update if the subassembly decryption changes.
If you need help with the iLogic please let me know.
I hope that made some kind sense and helps in some kind of way
JD
Hi everyone,
I've created an Idea Station idea for this. You can use this link to give the idea a kudo to show that this is something you would find useful:
I hope this helps.
Curtis
I posted how to use the work around on this other post.
http://forums.autodesk.com/t5/Autodesk-Inventor/Leader-Text-Question/m-p/4317172#M475547
Hope this helps.
