I want to change the leader text and lines to a unique color however the 'Style' button is grayed out in the format text box. Also any attempts to change the line color results in a global change. Is there another location within Inventor for changing the leader style?
Solved by cbenner. Go to Solution.
Did you try Manage/Styles Editor?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
That solved the line color & arrow formatting but not the text format issue.
In Styles Editor, create or edit a Text Style that includes the text formatting you want. Then create or edit a Dimension style that uses that Text style. Then go to Object Defaults and find "Leader Text" and assign that Dimension Style to it. Between these things you should be able to get any combination you want for your leaders and text.
Chris Benner
i agree, but all these different options end up giving you a lot more flexibility long term, you can make almost infinite combinations that let you completely customize your drawings.
Chris Benner
The 'object defaults' is an area that I never investigated - now that I know it is there it should be the key to changing a few other things that I couln't isolate before.
Thanks.
@joel.McKone wrote:The 'object defaults' is an area that I never investigated - now that I know it is there it should be the key to changing a few other things that I couln't isolate before.
Thanks.
this may help:
http://mfgcommunity.autodesk.com/files/20301_20400/20363/file_20363.pdf
I used to struggle with Inventor styles too, but after you understand what's going on, they're suppressing intuitive.
It's been that way pretty much since the beginning. I can only guess what the original developers were thinking, but my guess is that they saw a leader note as being a part of the dimension family.
Chris Benner
