Inventor Forum
Leader Text
9 REPLIES 9
Message 1 of 10
JoelMckone
3132 Views, 9 Replies
Leader Text
I want to change the leader text and lines to a unique color however the 'Style' button is grayed out in the format text box.  Also any attempts to change the line color results in a global change.  Is there another location within Inventor for changing the leader style?
Tags (1)
9 REPLIES 9
Message 3 of 10
JoelMckone
in reply to: JoelMckone
That solved the line color & arrow formatting but not the text format issue.
Message 4 of 10
cbenner
In Styles Editor, create or edit a Text Style that includes the text formatting you want.  Then create or edit a  Dimension style that uses that Text style.  Then go to Object Defaults and find "Leader Text" and assign that Dimension Style to it.  Between these things you should be able to get any combination you want for your leaders and text.
Message 5 of 10
JoelMckone
in reply to: cbenner
A little convoluted, but it works.
Message 6 of 10
cbenner
i agree, but all these different options end up giving you a lot more flexibility long term, you can make almost infinite combinations that let you completely customize your drawings.
Message 7 of 10
JoelMckone
The 'object defaults' is an area that I never investigated - now that I know it is there it should be the key to changing a few other things  that I couln't isolate before.
Thanks.
Message 8 of 10
Thanks.
this may help:
http://mfgcommunity.autodesk.com/files/20301_20400/20363/file_20363.pdf
I used to struggle with Inventor styles too, but after you understand what's going on, they're suppressing intuitive.
Message 9 of 10
blessing86
@cbenner any idea why it's attached to a dimension instead of a text style? I mean it is leader text isn't it?
Message 10 of 10
cbenner
in reply to: blessing86
@blessing86
It's been that way pretty much since the beginning.  I can only guess what the original developers were thinking, but my guess is that they saw a leader note as being a part of the dimension family.
