Two methods in Inventor....
1. This part looks like it could be cut using an angled sketchplane and an
extrusion.
2. If the above method does not suit the part it could be done using an
emboss or a split with a 3D sketch.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
wrote in message news:5674645@discussion.autodesk.com...
I am attaching some files of something that I would like to be able to do in
Inventor that we are currently doing in Solidworks. The tube that I have
attached is cut using a laser. The attached solidworks file is a 2007 file.
If you can view Solidworks files, you can see that this part is built using
a radiate surface feature. Is there something similar in Inventor, or is
there a different way to accomplish the same thing? I haven't seen the laser
acutally cut anything yet, but I am goin
g to head out to the shop floor to see it in action today.
I am using Inventor 2008.
Kevin
