If you are on R11, you can take advantage of Design Views and Level of Detail
representations to remove unnecessary components from the Derive process. While this may
not be optimal for all workflows, in cases where the internal components are not necessary
for the intended use of the Derived Assembly part, this can help speed the process
considerably.
I'd also recommend excluding parts with overly complex surfaces, such as coils, when
possible.
As a last option, try deriving different portions of the assembly into separate Derived
assemblies, place them into a new assembly, and make a final derive. This will break up
the boolean operations.
Pete
Peter Maxfield
Product Design, Autodesk Inventor
wrote in message news:5392300@discussion.autodesk.com...
I am having trouble trying to derive large assemblies. It just never accomplishes it. I
have let it run over night before, and when I come back in the morning it still just
sitting there with an hour glass stairing at me. Is there any other way to convert an
assembly into a part?
Message was edited by: shastu
