Inventor General
Valued Contributor
rich
Message 1 of 21 (999 Views)
Knurling
999 Views, 20 Replies
10-19-2007 07:04 AM
Is there a way to knurl just a small piece of a part without turning the material for the whole part to knurled?
Distinguished Contributor
albender
Message 2 of 21 (999 Views)
Re: Knurling
10-19-2007 07:07 AM in reply to: rich
A work around that I have used is to set as knurl then extrude ends 0.0005
*Expert Elite*
JDMather
Message 3 of 21 (999 Views)
Re: Knurling
10-19-2007 07:27 AM in reply to: rich
Yes, can you zip and post what you have so far? (The ipt that is.)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
JDMather
Message 4 of 21 (999 Views)
Re: Knurling
10-19-2007 07:32 AM in reply to: rich
Here is a quick example.
Valued Contributor
rich
Message 5 of 21 (999 Views)
Re: Knurling
This one has a .5" straight knurl starting .1" from the tapered section going away from the taper
Valued Contributor
rich
Message 6 of 21 (999 Views)
Re: Knurling
10-19-2007 07:36 AM in reply to: rich
This one has a 1" diamond knurl starting at the tapered section going away from the taper.
*Expert Elite*
JDMather
Message 7 of 21 (999 Views)
Re: Knurling
10-19-2007 07:48 AM in reply to: rich
Your sketches do not have any dimensions and are not constrained to the origin. How did you create a precise sketch with no dimensions?
Check out this document
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
You can control a color (texture) by part, by feature or by face properties. RMB on feature in browser or on face to change properties.
The scale of the texture can be changed in the Style Editor.
Pull down the red End Of Part marker in the browser.
*Dennis Jeffrey
Message 8 of 21 (999 Views)
Re: Knurling
10-19-2007 08:06 AM in reply to: rich
Here's one using a split face and the Metal-Steel Knurled style.
Observations:
1. Your part is far from the origin. Why?
2. Even if this was an imported DWG, then you still need to constrain,
dimension and anchor
3. I had to go back to the sketch and throw out a dim to determine where to
place the splitting plane accurately.
This takes time. Do you have a lot of it?
4. This is easily accomplished using a split face and then selecting the
desired face, RMB and select properties for that face.
A machine designer probably would not go to the trouble of creating a
physical knurl on a part in an overall large assembly. I can see it for a
detail presentation or rendering, but anything other than a bitmap will
bring performance issues in a large assembly that utilizes a quantity of
parts with this kind of detail.
Not to mention the time required to create physical details.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
wrote in message news:5755042@discussion.autodesk.com...
Valued Contributor
rich
Message 9 of 21 (999 Views)
Re: Knurling
10-19-2007 08:20 AM in reply to: rich
I use the dimentions to place my lines and etc. but then I delete them so they don't get in my way and clutter the work space.
Valued Contributor
rich
Message 10 of 21 (999 Views)
Re: Knurling
10-19-2007 08:27 AM in reply to: rich
Sorry i said it wrong the krul is 1" long and on the other one thr knurl is .5" long starting from the points given. I import the drawings from MDT but the drawing is not on the origin hense the distance of the origin.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
