Inventor Forum
Knurling
20 REPLIES 20
Message 1 of 21
rich
1705 Views, 20 Replies
Knurling
Is there a way to knurl just a small piece of a part without turning the material for the whole part to knurled?
20 REPLIES 20
Message 2 of 21
albender
in reply to: rich
A work around that I have used is to set as knurl then extrude ends 0.0005
Message 3 of 21
JDMather
in reply to: rich
Yes, can you zip and post what you have so far? (The ipt that is.)
Message 4 of 21
JDMather
in reply to: rich
Here is a quick example.
Message 5 of 21
rich
in reply to: rich
This one has a .5" straight knurl starting .1" from the tapered section going away from the taper
Message 6 of 21
rich
in reply to: rich
This one has a 1" diamond knurl starting at the tapered section going away from the taper.
Message 7 of 21
JDMather
in reply to: rich
Your sketches do not have any dimensions and are not constrained to the origin. How did you create a precise sketch with no dimensions?
Check out this document
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
You can control a color (texture) by part, by feature or by face properties. RMB on feature in browser or on face to change properties.
The scale of the texture can be changed in the Style Editor.
Pull down the red End Of Part marker in the browser.
Message 8 of 21
in reply to: rich
Here's one using a split face and the Metal-Steel Knurled style.
Observations:
1. Your part is far from the origin. Why?
2. Even if this was an imported DWG, then you still need to constrain,
dimension and anchor
3. I had to go back to the sketch and throw out a dim to determine where to
place the splitting plane accurately.
This takes time. Do you have a lot of it?
4. This is easily accomplished using a split face and then selecting the
desired face, RMB and select properties for that face.
A machine designer probably would not go to the trouble of creating a
physical knurl on a part in an overall large assembly. I can see it for a
detail presentation or rendering, but anything other than a bitmap will
bring performance issues in a large assembly that utilizes a quantity of
parts with this kind of detail.
Not to mention the time required to create physical details.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
wrote in message news:5755042@discussion.autodesk.com...
Message 9 of 21
rich
in reply to: rich
I use the dimentions to place my lines and etc. but then I delete them so they don't get in my way and clutter the work space.
Message 10 of 21
rich
in reply to: rich
Sorry i said it wrong the krul is 1" long and on the other one thr knurl is .5" long starting from the points given. I import the drawings from MDT but the drawing is not on the origin hense the distance of the origin.
Message 11 of 21
in reply to: rich
Why not just open the MDT part in Inventor? No need to recreate...
260-399-6615
wrote in message news:5755206@discussion.autodesk.com...
Message 12 of 21
robvacsax
in reply to: rich
ROFLMAO
ROb
Rob - User since release 10
System specs
Inventor 2020
Processors: 8x Intel core i-7 7820X 32GB ram
Video: NVIDIA Quadro P100
Message 13 of 21
RonnieWilkins
in reply to: rich
Discussion Group is addictive isn't it...
How's the book going?
Ronnie Wilkins, Jr.
Message 14 of 21
RonnieWilkins
in reply to: rich
Do not, I repeat...
DO NOT DELETE DIMENSIONS UNLESS THERE IS AN ERROR IN YOU SKETCH DESIGN INTENT!!!
^^Yeah, I am SCREAMING AT YOU!
If you want to cleanup your workspace, find the sketch in the browser and uncheck Dimension Visibility
Ronnie Wilkins, Jr.
Message 15 of 21
aardvark
in reply to: rich
I can't believe you actually said that! What happens when you need to change the model? Do you go back and re-dimension everything? This isn't ACAD.
Message 16 of 21
albender
in reply to: rich
ROFLMAO, What the heck is that?
Message 17 of 21
aardvark
in reply to: rich
Rolling On Floor, Laughing My A$$ Off
Message 18 of 21
albender
in reply to: rich
Oh OK thanx
Message 19 of 21
albender
in reply to: rich
Your dimensions serve to constrain your part so that when you want to make any changes down the road your changes will be predictable and avoid any head aches or night mares.
Message 20 of 21
JDMather
in reply to: rich
In MDT the first thing you should do is create origin planes and use them. Put them in your template. I'm a but surprised that your teacher lets you get away with these inefficient modeling practices.
