Inventor Forum
Kfactor
3 REPLIES 3
935 Views, 3 Replies
Kfactor
Hi all
Which true value of Kfactor in Sheet Metal can I use to work with
thikness (metric system) 1 mm - 1.2 mm - 1.5 mm - 2 mm - 3 mm - 4 mm - 5
mm - 10 mm - 20 mm ??
I am confused about that
Thanks for any suggestions
Sergio Cometto from Italy
3 REPLIES 3
Kfactor is specific to the material and condition of material. Most shops
either use standard values as approximations or determine them
experimentally. The thinner the material the less critical the kfactor
becomes. What material and thickness are you working with?
Pat
"Sergio Cometto" wrote in message
news:74141F32DF1A28F7638847AB7B2A2F81@in.WebX.maYIadrTaRb...
> Hi all
Berry
I work normally with steel or AISI 303 or 304
Where I can get Kfactor for that?
Thank you
"Patrick Berry" ha scritto nel messaggio
news:06FE3ECEBB117522C3C54CCE15090F1D@in.WebX.maYIadrTaRb...
> Pat
> > Hi all
5
The Machinists Handbook gives .55 for Al and Brass, .64 for soft steel and
.71 for cold rolled steel. Stainless is notoriously anisotropic and
sensitive to grain direction but a K factor of about .65 should get you
fairly close. Sheet metal workers normally determine these values
experimentally based on the materials they commonly work with. This value
is much less critical with thinner sheets than thicker ones. If you don't
have sheet metal capabilities in house your best bet is to just give the
shop a drawing of the finished part and let them work out the bend
tolerances. Hope this helps.
Pat
