Inventor General
Member
ankittpatel
Message 1 of 9 (1,030 Views)
Keyway on a shaft
1030 Views, 8 Replies
07-21-2006 06:10 AM
How can i sketch a keyslot on a shaft? if i create a workplane at certain distance than I am not able to snap/grab the points.
what is the best way to draw anything onb a cylindrical surface? see attached pic, need help
*Don J \(IV11SP1. IV10SP3a\)
Message 2 of 9 (1,030 Views)
Re: Keyway on a shaft
07-21-2006 06:22 AM in reply to: ankittpatel
wrote in message news:5244392@discussion.autodesk.com...
project geometry
Distinguished Contributor
hallstevenson
Message 3 of 9 (1,030 Views)
07-21-2006 06:24 AM in reply to: ankittpatel
Project the center point of the model itself, sketch a (center) line from that center point, then draw your slot. I located it some distance from an existing shoulder by dimensioning to that shoulder, without having to project it, by the way.
*Expert Elite*
JDMather
Message 4 of 9 (1,030 Views)
07-21-2006 06:28 AM in reply to: ankittpatel
Can you post what you have so far?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*JerryAcidNL
Message 5 of 9 (1,030 Views)
07-21-2006 06:30 AM in reply to: ankittpatel
Design Accelerator
Jerry
schreef in bericht news:5244392@discussion.autodesk.com...
Valued Mentor
pcunningham1
Message 6 of 9 (1,030 Views)
07-21-2006 06:32 AM in reply to: ankittpatel
"if i create a workplane at certain distance than I am not able to snap/grab the points"
What points do you mean?
Put the workplane where you want the bottom of the keyseat, new sketch (F7 to view the sketch plane), sketch the keyseat, extrude cut thru all
-Paul Cunningham IV10sp3a
Paul Cunningham
IV2008
Member
ankittpatel
Message 7 of 9 (1,030 Views)
07-21-2006 06:54 AM in reply to: ankittpatel
i cant draw key anywhere, it has to be symetrical to axis of shaft, how could i use those points or axis of shaft to draw a keyway on this new workplane
Member
ankittpatel
Message 8 of 9 (1,030 Views)
07-21-2006 07:06 AM in reply to: ankittpatel
thanks everybody, project geometry would be the right answer for me, thank you all
*cbliss
Message 9 of 9 (1,030 Views)
07-21-2006 09:58 PM in reply to: ankittpatel
Have you considered using the keyway generator in Design Accelerator?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
