Inventor General
Distinguished Contributor
Message 1 of 7 (704 Views)
Accepted Solution
Keep drawing view annotations fixed relative to geometry
704 Views, 6 Replies
05-08-2013 06:17 AM
I'm sure this has been asked many times but none of the queries I used brought up a similar question. My issue is that I recently spent a lot of time annotating a detail view with leaders attached to geometry, leaders not attached to geometry, and sketches constrained to geometry projected from the view. I made some modifications to the model which didn't re-locate any of the components that I'd annotated, but somehow the detail view got shifted, and all of my leaders are pointing to the wrong place and the parts of my sketch that weren't constrained to geometry are in the wrong place as well. Some of the leaders seem to have held to ther posts better than others, but for the most part my annotations are worthless and will need to be re-done.
Has anyone else experienced this, and does anyone know of a way to prevent it in the future? Any suggestions are appreciated.
graemev
Message 2 of 7 (687 Views)
Re: Keep drawing view annotations fixed relative to geometry
05-08-2013 08:34 AM in reply to: DRoam
Did you have a drawing view selected when you crerated the sketch for the annotations?  If not, the sketch is only for the sheet at large and will not travel with the view, nor respond to changes in geometry within the view.
For sketches created when a view is highlited, the view geometry becomes "projectable" and all sketched elements will move and update with the view.  For annotations not touching projected geometry directly, I prefer to place a "sketch only" point that is dimensioned back to some relevant projected geometry so that any updates to the geometry will affect the otherwise unattached annotations.  It's a bit of a pain setting it up, but less of a pain than repositioning all the annotations.
Valued Mentor
jeanchile
Message 3 of 7 (677 Views)
05-08-2013 10:08 AM in reply to: DRoam
Was the detail view "attached"? Also, there are settings under document settings for drawings where you can preserve orphaned annotations and specify dimension text locations, have you tried those?
We've had similar problems in the past (even had AD log a bug fix at one point... which hasn't been fixed of course) but we have had better success by playing with the two items I mentioned above. Good luck!
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
Message 4 of 7 (665 Views)
05-08-2013 01:03 PM in reply to: jeanchile
Thanks for the reply, jeanchile. Can you explain what you mean by having the detail view "attached"? I'm not sure I'm familiar with this.
No, I didn't know about the "perserve orphaned annotations" option, that might solve some issues--actaully thought I haven't noticed any issues of annotations disappearing, just moving to the wrong place. But thanks for the tip!
Valued Mentor
BLHDrafting
Message 5 of 7 (656 Views)
05-08-2013 03:17 PM in reply to: DRoam
Try this blog entry.
http://blogs.rand.com/manufacturing/2013/01/attachment-to-detail-its-the-little-things.html
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
Valued Mentor
jeanchile
Message 6 of 7 (635 Views)
05-09-2013 10:36 AM in reply to: DRoam
The blog post above shows the "attachment" of the detail views. This picture shows the two setting we adjusted to get results that were better:
We still have dimensions moving all over the place when we change something and we still have AD telling us that they have logged the issue, but we still continue to have problems. At least now when our models change, some of the dimensions stick around for us to re-attach.
Good Luck!
Message 7 of 7 (613 Views)
05-10-2013 06:30 AM in reply to: jeanchile
I don't know exactly why my detail views moved in the first place so I can't test it, but it sounds like the detail attachment option is exactly what I need. That combined with the options jeanchile pointed out should save me a lot of drawing view headaches. Thanks for the tips!! Thanks also to graemev for the tip about constraining sketches with sketch-only geometry, that will be useful as well.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
