Ron:
If your joggles are greater than material thickness this can be
accomplished.
Granted, it'll probably be more of a pain than you want to deal with,
but possible none the less. I put a sample file in CF.
FWIW:
I would personally go the other route and add you joggles first.
Another reason it would still be nice to re-ordering things?
"Ron Crain" wrote in message
news:92DC931B3E6CA6E4DE8DD2EB0A3EF5A6@in.WebX.maYIadrTaRb...
> Current material thickness is 1.2mils 🙂
> I would like joggles greater than material thickness.
> "Ken Schumacher" wrote in message
> news:99848210310A8422D9CBB8AC24DAB180@in.WebX.maYIadrTaRb...
> > What thickness mat'l are you using?
> > How much of an offset are you looking for, a thickness? (This probably
> can't
> > be done)
> > Can you crank down your bend radius for that bend to say....0001 in?
> > news:4A1D29B1AA211F42B729ED27A58108E4@in.WebX.maYIadrTaRb...
> > > That works for adding new material, I'm trying to do it with existing
> > > material - similar to using the "Fold" command.
> > > news:085B66C6ECE3CC9055339E0B1630351A@in.WebX.maYIadrTaRb...
> > > > Ron have you tried adding a flange at 0 degrees?
> > > > Maybe I'm misunderstanding you.
> > > > news:FED5AE8C27C65BA643C4B31863DAC807@in.WebX.maYIadrTaRb...
> > > > > Has anyone found a way to create an offset joggle in sheetmetal in
> an
> > > > > operation similar to a Fold? I would like to add a joggle to a
face
> > > which
> > > > > has multiple cutouts.
