Inventor Forum
Jogged Dimensions
1 REPLY 1
JohnChisholm
1783 Views, 1 Reply
Jogged Dimensions
Is it possible within an Inventor 2013 dwg to create a "jogged" linear dimension ?
I am aware that a jogged radial dimension is possible.
I currently have an enlarged detail which incorporates a large radius which has it's centre point outwith the drawing border & I need to add a dimension to this centre point.
1 REPLY 1
SBix26
in reply to: JohnChisholm
As you can see in my signature below, this is a feature that is missing from Inventor.  The jogged radial dimension is useless: all it does is remove part of the dimension line and terminate it with a little squiggle symbol.  To get a linear dimension to show appropriately, you need to create a broken view, but you can't do this outside the part geometry.  So the only workaround that I have found is to create a feature (a very small inobtrusive feature) at the radius center.  Then you can create a broken view, and dimensions to the radius center will display properly, except for the radius.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
