Inventor General
Valued Contributor
Terry__Close
Message 1 of 7 (265 Views)
Accepted Solution
JD-sheet metal
265 Views, 6 Replies
10-18-2012 04:58 AM
Not sure if you are still going to provide the example in Sheet Metal you mentioned....just let me know if you do not have time and i will cease asking as i would presume your busy
http://forums.autodesk.com/t5/Autodesk-Inventor/rail-holes/td-p/3657028
Best Regards
Terry
*Expert Elite*
JDMather
Message 2 of 7 (263 Views)
Re: JD-sheet metal
10-18-2012 05:00 AM in reply to: Terry__Close
I will try to get to it today - kind of surprised that someone else didn't jump in here and show a solution as this one is easy.
Did you try the Help with Rolled Contour and Unfold/Refold?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
mrattray
Message 3 of 7 (255 Views)
Re: JD-sheet metal
10-18-2012 05:20 AM in reply to: Terry__Close
Here's an example of one side. I made up the dimensions, but you can follow the workflow to make your own piece.
Mike (not Matt) Rattray
Valued Contributor
Terry__Close
Message 4 of 7 (182 Views)
Re: JD-sheet metal
10-19-2012 05:18 AM in reply to: mrattray
Thanks Mike
Valued Contributor
Terry__Close
Message 5 of 7 (137 Views)
Re: JD-sheet metal
10-20-2012 06:20 AM in reply to: JDMather
JD...are you able to how your solution or example?
Cheers,
Terry
*Expert Elite*
JDMather
Message 6 of 7 (135 Views)
Re: JD-sheet metal
10-20-2012 06:30 AM in reply to: Terry__Close
Milke already posted solution same as what I would do.
Actually I suggested Unfold/Refold because I was not aware that Inventor would Project Flat Pattern with a Roll Contour (never tried it, but I was thinking about it with your problem, so hopefully I would have discovered the same solution). :smileysurprised:
Either way will work.  I prefer Mike's solution when it will work rather than Unfold/Refold.
The key to Project Flat Pattern is you must start your sketch on a planar face rather than a workplane.
Then select the extants you want to project.
Valued Contributor
Terry__Close
Message 7 of 7 (131 Views)
Re: JD-sheet metal
10-20-2012 06:36 AM in reply to: JDMather
Thanks a lot for the help....appreciated
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
