There a few dodgy things goign on with my BOM.
I imported a BOM style from another drawing that worked fine, but when I edited the names of teh columns it broke everything again.
THere's a few thigns wrong.
There's no item numbers.
It says the QTY is incompatible units????
And there's teh funny table like icon with an arrow pointing to it with my parts highlighted blue. What does this mean?
Again, everything was fine until I changed the names of the columns and changing the naems back doens't fix it.
Solved by -niels-. Go to Solution.
First off... what version of Inventor is this? Next, is this a drawing parts list or an Assembly BOM? Looks like a drawing parts list. Did you simply change the name of the columns, or the properties associated with them?
The units issue makes me think that in your BOM there must be parts with the same stock number that have different units assigned. Any chance of getting a screen shot of the Assembly BOM?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
YES! They were grouped. I've not used that feature before so I didn't recognise the icon.
Thanks!
The grouping was specified in the styles settings which is why I didn''t notice.
