Inventor Forum
Issue with 2013 update 4 SP2
4 REPLIES 4
BarryZA
305 Views, 4 Replies
I am still on 2013 Pro 64 bit. After a few crashes recently I installed SP2 and encountered an issue:
If I have an assembly open and change tabs, then come back to the assembly, a whole lot of the parts have dissapeared from my screen.
The only way to get them to appear is to click on them in the browser.
Tried installing update 4, but it dosen't help.
(Win 7 pro, 64 bit)
If I can't resolve this I suppose I need to do a system restore.
4 REPLIES 4
stefaanboel
in reply to: BarryZA
Is your video driver up 2 date?
Try also the Hardware settings in the application options. Switch to a different one and then switch back to what you had before (I my case that's Performance) ,that action makes sure the registry files are reset.
If this is the solution, push the solution button Smiley Wink (and maybe some kudos)
BarryZA
in reply to: stefaanboel
Thank-you squire, looks like I've opened a can of worms here.
O, for a unified update manager like in Ubuntu Smiley Wink
BarryZA
Solved!
One "complication", I had to close all my tabs in Inv. first, before changing the hardware settings for it to work.
Much obliged.
stefaanboel
Great!
Thanks for the extra info, I'll remember the "close all tabs" part 🙂
