Inventor General
Active Contributor
shuaib_cad
Message 1 of 3 (224 Views)
Issue in Counterbore hole in Hole feature
224 Views, 2 Replies
11-25-2013 07:16 PM
I am facing an issue in Autodesk Inventor.
The counterbore hole option in the hole feature has the tap depth from the top surface.
We have to always add the counterbore depth to the tap depth. For example, (counterbore depth + tap depth).
If we use the spot face hole option. We don't get the counterbore depth in hole notes in the drawing. The depth of the counterbore has to be typed manually in the hole notes.
Please see the attached image and advice.
Regards
K. Mohammed Shuaib
Valued Mentor
BLHDrafting
Message 2 of 3 (211 Views)
Re: Issue in Counterbore hole in Hole feature
11-25-2013 08:17 PM in reply to: shuaib_cad
I'm thinking this is how your Styles are set up. There are about 40 odd settings for all of the different hole/thread/counterbore/etc... combinations the HOLE command can make. You can set them up how you want.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
Mason-Paul
Message 3 of 3 (126 Views)
11-28-2013 01:58 PM in reply to: shuaib_cad
The FIRST example in the diagram in the previous post is the correct method of indicating a counter bored hole ie THREAD DIAMETER & Pitch NUMBER OF THREADS  OF A TAPED HOLE or DIAMETER OF A PLAIN HOLE- OVERALL DEPTH OF TAPED/ PLAIN HOLE then the DIAMETER OF THE COUNTER BORE  - DEPTH OF COUNTER BORE from the face from which the hole was drilled as this is considered the datum plane/point.
Inventor 2013 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Mhz CPU , 32 GB Ram
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
