I would like to work on 1/4 of this part then mirror it twice to make a complete part. I have tried to mirror it about 10 times and Inventor just locks up.
Is there a different way I should be splitting it? I am using Inventor 2013.
I was able to do the two mirrors in r2014.
Are you attempting to mirror by feature or by solid body?
Edit: locked up 2013 though.
Use Mirror a Solid in the Mirror command. Pick the model and then select a mirror plane.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
What I posted earlier was done on 2013.
Chris Benner
So it is working for you on Inventor 2013. It's still locking up here. I guess I need to figure out how to contact Autodesk tech support.
Thanks for trying it guys.
Are you on Subscription?
There is a Tech Support link on the Subscription website.
Chris Benner
Hi
I cannot see why 2013 hung, might be hardware, as it appears to have worked for others, when I did the first mirror, 2014 paused for a few seconds, the second mirror was instantanious. (Odd)
A work around for the moment could be to shell the entire part as shown in the screen dump. Select the lower face and the rear face for removal.
I suppressed the fillets one at a time and found that to be my problem. One of the fillets was creating a detached face when mirrored.
I rebuilt the part from the beginning and it is good now.
