I've noticed when I was making a drawing with the standard title block that when I'm done it inputs the part number of my part into the part number block in the title block.
I've since made my own title block, but have lost this feature. How do I get it so that when I put a part in, it puts that part number into that location of my title block? Would it be possible to also have it input the material the part is made from?
Thanks!
Hi JoeScizz,
Here are a couple of videos that will walk you through it, as well as some help file links:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-97753A27-FCD6-4037-8DF4-E999A39783AE
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-3E1B9A3D-8362-4638-BE82-D8B10ACDA4C8
I hope this helps.
Curtis
