Inventor General
Active Member
Message 1 of 3 (154 Views)
Is there a revolution constraint for a bolt?
154 Views, 2 Replies
07-19-2012 02:22 PM
I've assembled a bolt and a slide block that is constrained to a base plate  and am able to put everything in motion.  I have the slide block constrained to slide the distance of the base plate and when I reach the end the bolt continues to rotate when, if this was a real part, should stop.  How can I get this bolt to stop once the slide block reaches its ending constraint?
Curtis_Waguespack
Message 2 of 3 (153 Views)
Re: Is there a revolution constraint for a bolt?
07-19-2012 02:31 PM in reply to: aaronfue
Hi aaronfue,
Most likely you'll want to place an Angle Constraint and then use the >> button to expand the options and add the Constraint Limits information to define the range of motion.
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/3364-Show_Me_3364/3365-Show_Me_3365/3596-Assembl...
Also  just as an FYI for future reference, when you attach an assembly file you'll need to attach the part files also, otherwise when we download the assembly file it is empty.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 3 of 3 (140 Views)
07-19-2012 03:21 PM in reply to: aaronfue
You posted an iam file.
An iam file is useless without the ipt files.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
