Inventor Forum
Is it possible to use a material to change the color of texts?
5 REPLIES 5
368 Views, 5 Replies
In a project I'm working on I need to make the text have mirror properties. But when editing the text all i can choose from is "normal" colors.
So is there any way to make text use materials, like you do on normal surfaces?
5 REPLIES 5
JDMather
Can you post file?
Is this sketch text, feature, drawing?
CCarreiras
Hi!
You can use the text to split face, or doing a emboss with a very small values, and then select the faces, properties and select a mirror color like chrome.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
in reply to: CCarreiras
Thanks for the really quick answer! Like you said, if I choose like 0.001mm it's not even going to be noticeable.
JDMather
You can do Split on the face and have zero (0) offset.
The only problem is you have to do it for each letter.
in reply to: JDMather
Okay, so if I have a normal text on a surface, how exactly should I go on about doing that? I'm quite new to Inventor, and has not used the split tool before.
