Im doing some pictures for a broschure.
There are several products to render out and I like each product to be viewed in same position.
When i rotated the product in a view i like can I save the position coordinates and set them later in another product?
Or do anyone have a tip to get the same view position all the time?
Probably create a workplane in your part and then in the idw "Look At" the workplane. You would want to base the workplane on origin based geometry so that they are always the same.
Or..
Place each part in an assembly and rotate it to the desired angle and then just create a normal "Front" view in the idw. This method is probably easier but you end up with an iam for each part as well. I have used this when creating skeletal parts that are not "normal" to the origin workplanes.
Try placing each of the part into one assembly.
Constrain the parts so that they are orientated the way you desire.
Once you have this assembly created, you have a couple options.
