Inventor Forum
Is it possible to create a weld build up around a part?
3 REPLIES 3
hhls11
698 Views, 3 Replies
I'm starting with a tube and want to add a weld build up around the OD on both ends. I mainly want to do this so that when I create a sectioned view on a drawing, you can see the difference in hatching between the original tube and the weld build up. I've had to create sketches on the drawing up to this point, but that's kind of a hassle. Is there any way of doing this?
The photo I've attached shows the tube and shape of the weld build up. the green line is where I would like the tube OD to be, and the weld build up would be everything above that.
I'm using Inventor Pro 2013.
Thanks in advance.
Inventor Professional 2021
Intel Core i7-9700K @ 3.60Ghz
16GB DDR4 RAM
NVIDIA GeForce RTX 2060 Super GPU
Windows 10 Professional 64-bit
3 REPLIES 3
Ryan.Martinez
in reply to: hhls11
Call it out with a note?
P.D.S. 2015
P.D.S. 2016
harco
in reply to: hhls11
Not sure without trying but the split tool may give you what you want.
If not use a very thin cut to give an edge.
japike
in reply to: harco
Add the weld build up to your part as a new solid body.
Peace,
Jeff
Inventor 2022
