Inventor General
Active Member
Message 1 of 1 (126 Views)
Is it possible to change parameter value of derived sketch block?
126 Views, 0 Replies
11-02-2012 09:23 AM
This may require a more advanced feature, but if I use sketch blocks, and have a part that derives and imports these blocks, is it possible to make these flexable by changing a paramter of the sketch block?  For example if I have a sketch block that uses stock_thickness to be define various dimensions, and I want to use sketch block, but I need to change this stock_thickness.  If this is more than sketch blocks are used for, what can I use for this?
Thanks.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
