Inventor General
New Member
oefossan
Message 1 of 5 (134 Views)
Is it possible to change one of the Positions to be the Master position?
134 Views, 4 Replies
02-15-2007 02:11 AM
I have made an assembly with a lot of "Positions" (in the Representations). See browser.
Is it possible to change/edit one of the Positions (In the Representation tree) to be the Master Position?
andrewiv
Message 2 of 5 (134 Views)
Re: Is it possible to change one of the Positions to be the Master position?
02-15-2007 08:36 AM in reply to: oefossan
I don't know of any way to do this, but I've often thought that this would be very helpful.
Inventor Professional 2014 SP2
Valued Contributor
bcrowell
Message 3 of 5 (95 Views)
04-11-2012 05:59 AM in reply to: oefossan
I need to do the same thing- have you had any luck finding a way to do this?
Inventor 2013 (SP2 Update 2), Windows 7 Professional (64-bit), SP1, Intel Xeon 3.07GHz CPU, 12GB RAM, NVIDIA Quadro 2000, Vault Basic 2013
Valued Contributor
nannerdw
Message 4 of 5 (90 Views)
04-11-2012 06:16 AM in reply to: oefossan
I'm not sure how that would work, since the positional reps are defined by overriding the master rep.
I'd probably set the browser view to "Represntations", and recreate all of the overridden constraints in the master view.
Usually I'll use iLogic in place of positional reps, so I don't have to switch back and forth to the master view to make changes to parameters.
-Using Autodesk Inventor Professional 2012
Valued Contributor
bcrowell
Message 5 of 5 (83 Views)
04-11-2012 07:15 AM in reply to: nannerdw
I haven't messed much with the iLogic but need to get familiar with using it.
What I was doing was taking an existing assembly, moving components with a positional representation in order to try and get the center of gravity back in check after some assembly modifications.  I figured that I wouldn't have to go back and forth with changing them back to what the customer had approved versus what I needed to change them to, but it was also before I found out that you couldn't save a file in a positional representation (what?!?).
I figured changing the master would be a simple matter of changing the overrides to the norm so I could delete the positional representation.  Apparently it isn't so simple.  Hopefully iLogic is the answer.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
