Inventor Forum
Iproperties - description - .idw
7 REPLIES 7
Message 1 of 8
nike_bytom
781 Views, 7 Replies
Hi there,
Can any one help me with my drawing template.
Is there any way  to automaticly fill in description in iProperties (.idw) from model description?
Ilogic?
Need simple solution
Raf
7 REPLIES 7
Message 2 of 8
mcgyvr
in reply to: nike_bytom
edit title block.. place text and see attached image..
No need for ilogic..
Just straight out of the box how it should work from day 1 (maybe 2) of your training.
Message 3 of 8
nike_bytom
in reply to: mcgyvr
Thanks for that. must be something wrong then with template. this is already set in my border.In the border i got description from model but for some reason description in iproperties is empty. This is problem I am using vault so when I am searching for files using description i cant find files becouse description field ids empty in iproperties
Message 4 of 8
mcgyvr
Yes obviously the models description iprop must be filled in.
Message 5 of 8
nike_bytom
in reply to: mcgyvr
Yes iprop of model its filled in , description is in the border but not in iprop of idw ...Border
Message 6 of 8
mcgyvr
oops.. sorry... Now I understand what you were asking..
You want the description iproperty in the IDW files iproperties to be automatically populated
Here is how you do that..
Open your drawing template.. Go to tools..document settings..drawing tab and click on the "Copy Model Iproperty settings" button. Then simply check the "copy model iproperties" button and then put a check box by "description"
Then save template.
Now the drawing description iproperty will be automatically copied from the model iproperty when you place your first base view into the drawing.
Message 7 of 8
CCarreiras
Hi!
This is because the you have the iProperties from the model and iProperties from the drawing... each file has the propper iproperties and most of the times they are diferent.
If you wish to have the Drawing iProperties in the titleblock you have to edit the titleblock and insert the drawing iproperties:
Chose from here (see image below). Save as template for using later.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CCarreiras
Message 8 of 8
nike_bytom
in reply to: mcgyvr
One more question related to this topic. When i repleced my model reference in the drawing my discription in iproperties didn,t update but update in the border. Any way to set this to automatic update?
