Inventor Forum
Ipart with Custom parameter saves parts in the workspace
3 REPLIES 3
hendrikbreimer
354 Views, 3 Replies
when i create an ipart with an custom parameter column, the files are created in the workspace.
Is there any way how i can change this location?
Many parts are piling up in the workspace.
For example to the library (like "normal iparts" do) or to a folder in the workspace (workspace/custom_ipart_folder)?
Inventor 2013
Win 7 64bit
3 REPLIES 3
CCarreiras
in reply to: hendrikbreimer
HI!
When you are carrying the iPart member, you can chose the location.
Click "Browse" and select the location you want.
Regards
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
CCarreiras
ascott_shipco
in reply to: CCarreiras
Is there a way to set a default save path so that I am not constantly retelling the custom iParts where to save? I have tried setting a proxy path but they still default to the root of the project file.
@ascott_shipco
As far as I know there's no where of setting this.  I suppose you could set up frequently used subfolders in your project file and then when you save you could select it from the list when you browse.   In addition (and I could be wrong)..   I don't think proxy folders work anymore in the newer versions of Inventor.
Mark Lancaster
