Inventor Forum
Ipart not rebuilding in drawing
3 REPLIES 3
UpnorthSouth
350 Views, 3 Replies
Would anyone have an ilogic code to work around the Inventor bug of iparts not wanting to rebuild in drawings
after changes are made to the ipart.
3 REPLIES 3
mcgyvr
in reply to: UpnorthSouth
I think you can just create a rule to rebuild and trigger it on the "before save event"
You might need to run a rule to "regenerate" the members too but just try this first..
Just paste this in a new rule and try it...
ThisDoc.Document.Rebuild()
UpnorthSouth
in reply to: mcgyvr
     Appreciate your response and I did try that code yesterday before posting but it did not work. I still have to use my
work around Edit View\Model State\Active Family Member then select which configuation I want in the drawing.
I may not be doing the right thing with the rule. I'm adding the rule to the part file after the fact. The drawing was
already done and I decided to add a radius but it would not change in the drawing. I used rebuild all and regenerate
and it did not update.
IgorMir
Sometimes I run into the same situation. Not often enough as to give it a thorough investigation but. Try to delete the stubborn child Smiley Happy in a child folder and then re-generate it in a factory.
Igor.
Web: www.meqc.com.au
