a) you cannot modify library files. If the factory is in a path defined as
a library file you need to get out of IV and do 1 of 2 things
1)make a new project file that defines the ipart location as a local search
path or
2)move the ipart factory to a non library path, edit it, then return it to
the library path
b) to edit the ipart table you don't use the create ipart button. RMB on
the table in the browser and select either "Edit Table" or "Edit via
spreadsheet". I'd recommend the latter.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Jeem" wrote in message
news:1FE748FF3A91F0BCE2E115A99F4037EF@in.WebX.maYIadrTaRb...
> I'm trying to add a new value (material) to an existing Ipart factory and
> can only access Ipart Author through the Creat Ipart tab. Once in Ipart
> Author and I try and add the new value I get "Cannot modify the library
> file......."
> Do I need to unlock something?
