I created a Involute Spline in a assembly. However the Involute Spline at rotor is always over shot. Please see circle indication A in the rotor.png file. I attach my assembly file here. Please help. Thanks
Solved by JDMather. Go to Solution.
What size cutter are you going to use?
Don't just make up a size though.
Use an off-the-shelf size. It may turn out that you cannot avoid the over-cut. You might add a Chamfer to that edge.
