Solved by luis.guembes.c. Go to Solution.
Have you installed the Service Packs?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019#section16
Can you attach the file here
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
ll go with the service packs 1st and get back to you because I realy want to avoid reinstalling of all my autodesk products
I applied the service pack.
Before I would click simulate the loading bar would appear and dissapear almost instantly with no results shown.
This time it appears, and seems to be calculating, (computing results...)and about 10-20 seconds later it dissapears and shows no result.
After the SP failure I did the clean unninstall and the clean install and still nothing. The same as before, the bar starts loadingand stops at about 2/3rds of completition then it just dissapears without showing results. I tried with different files too. Created new ones just to test it and nothing.
Not sure what else I can do.
Search here for similar problems.
I think others might have experienced the same problem - but I don't recall the solution.
I went seraching found 143 pages worth of threads but checked quite a few. Anyway I read someting about corrupt usres which tbh I had not even considered. So I created a new standard user, ran Inventor normally(no admin rights) and the simulation works.
I tried running inventor with admin right in my administrator user and even worse, the simulation add-in was greyed out. I'm still very curious about inventor not working on my everyday user but so far I have this solution if anyone is interested.
TL DR
Create a new user and try if SA isnt working
