Inventor Forum
Inventor surface textures
6 REPLIES 6
Ross33
8306 Views, 6 Replies
I have modelled a component in Inventor ready for tooling. The component is modelled as an Inventor Part, but in reality is to be pressed steel. I have now been asked to add a textured finish to the product. The texture is stone. My plan is to roll back the features to prior to my shell operation, add the texture details (probably a combinations of adding and subtracting material), then rolling forward the features.
My question is, is there a good method of adding such a texture?! I've tried through sweeps etc, but they all look very sunthetic and not at all natural or "real". I've also spent the good part of the day trying to find a way to bring the file through 3ds max and to mudbox to sculpt, but this is also proving troublesome... and I certainly don't like the idea of bringing a non-adaptive/parametric model back to inventor.
Any help would be great.
Throw some ideas out there and hopefully something will work!
6 REPLIES 6
mcgyvr
in reply to: Ross33
Just create a new color style and add a "stone" texture map or bump map to that color style. Then apply that color style to the part. No need to model a texture.
Ross33
in reply to: mcgyvr
Sorry mate, but I need a physical texture in the surface as it will eventually dictate the tooling process.
mcgyvr
in reply to: Ross33
It is common practice to simply indicate required texture in the drawing. I've NEVER seen someone actually physically model a texture for a molded/stamped part.
One typically calls out the SPI or SPE standard in the print to dicate desired mold finish for injection molded parts. Or talk to your fabricator to discuss a suitable drawing callout to get the desired texture.
Never seen a "stamped steel" part with a "stone" finish though.. Are you sure this "finish" isn't just a wrinkle/textured powdercoat applied after fabrication or something like that.
Ross33
in reply to: mcgyvr
Yeah, it is a unique situation, hence the trouble I've had trying to model the component.
Thanks.
rdyson
in reply to: Ross33
I have no idea what you doing so this is truely a shot in the dark
In Rhino (download the trial if you don't have Rhino) open the texture bitmap
Use heightfield to create a surface based on the bitmap's changes in grayscale
See if you can use the resultant surface in IV
PDSU 2016
Ross33
in reply to: rdyson
Yep, I'm thinking that nurbs will be my only hope here.
