Inventor General
michaelmcgovern
Message 1 of 7 (471 Views)
Inventor stopped accepting text shortcuts (i.e.: "e" for extrude)
471 Views, 6 Replies
05-22-2012 05:34 AM
Until a couple weeks ago, I relied on several text shortcuts in Inventor (2012 Professional with SP1).  I don't know exactly what they're called, but for exemple I'd press "e" after creating a sketch and the extrude command would begin.  Also if I pressed "h", the hole command would begin.  These functions stopped working suddenly.
Now, whenever I press a letter key during Inventor operation, text appears at the bottom of the screen "Command alias input: [key]"  (See attached screenshot).
Any input would be greatly appriciated.
PaulMunford
Message 2 of 7 (451 Views)
Re: Inventor stopped accepting text shortcuts (i.e.: "e" for extrude)
05-22-2012 02:07 PM in reply to: michaelmcgovern
I think that you want to disable the command Alias input box:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0285-Work_Env285/0303-Customiz30...
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
michaelmcgovern
Message 3 of 7 (438 Views)
05-23-2012 08:33 AM in reply to: PaulMunford
That option is disabled in my Application Options.  If I check the "Command Alias Input" box, this causes a prompt to pop up when you start typing.  It appears to be very related to this, but that option is currently turned off and I'm still having problems with activating my shortcuts.
*Pro
sbixler
Message 4 of 7 (426 Views)
05-23-2012 11:42 AM in reply to: michaelmcgovern
This has happened to a number of Inventor 2012 users, me included.  You will have to re-establish those shortcuts by Tools > Options > Customize > Keyboard.  When you've got them back the way you want, Export to a location you can remember.  If (when) it happens again, you just have to Import to get them all back.  I still have no idea what causes this, nothing I can relate it to.  It seems random, and usually only a subset of the keyboard shortcuts are lost.
michaelmcgovern
Message 5 of 7 (424 Views)
05-23-2012 11:55 AM in reply to: sbixler
Good to hear I am not the only one.  I'll give that a try.  Just found another feature that has stopped working:  When I am sketching shapes (rectangle, line, circle) the ability to type a dimension after the first click no longer exists.  I have to draw a shape (2 clicks) then use the dimension command to add the first dimension to the shape.  There are a few other shortcuts that have stopped working but they slip my mind right now.
It's as if somebody turned off every feature that speeds up Inventor and makes repetitive tasks easier. I feel like there should be a checkbox somewhere that reads something like "disable all shortcuts" that I have to uncheck...
Product Support
bobvdd
Message 6 of 7 (394 Views)
05-30-2012 01:59 PM in reply to: michaelmcgovern
What happens if you reset your shortcut keys. Don't you get them back as one would expect?
You can do this in the Customize dialog > Keyboard tab > Reset all keys button
The dimension problem could be related to the following checkbox that is turned off:
Application Options > Sketch tab > Heads up display settings button > Create dimensions when inputting dimension value.
Bob
New Member
miloradrakić5843
Message 7 of 7 (279 Views)
12-30-2012 07:50 AM in reply to: michaelmcgovern
Try this:
1. Open Language bar (in Win7) & change language  to EN (United States)
2. Go to Inv2013: Tools, Customize, Keyboard and select Reset All Keys, Ok
It works for me!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
