Inventor Forum
Inventor sheet metal reducing elbow
21 REPLIES 21
Message 1 of 22
tcsteid
2298 Views, 21 Replies
anyone know how to create a reducing elbow in sheet metal? I need a 12" diameter to turn 90 degrees into an offset 8" opening.
21 REPLIES 21
Message 2 of 22
CCarreiras
in reply to: tcsteid
HI!
It's impossible to achieve the flat pattern of the elbow because it will have plastic deformation.
Maybe its better to do this in several elements and put them in one assembly.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 22
mrattray
Multiple parts (assembly), use lofted flange.
Post your attempt here if you need more help.
Mike (not Matt) Rattray
Message 4 of 22
CCarreiras
Hi!
If you need i can give this parametric assembly.
You can fill the fields with your values and achieve a lot of different systems with the same assembly.
CCarreiras
Message 5 of 22
tcsteid
in reply to: CCarreiras
I would very much appreciate the file.
Dave Steinhauer
David Steinhauer
Professor,
Certified AutoCAD Professional
Certified Autodesk Inventor Professional
Academic Advisor Naval Shipyard Apprentice Training Program
________________________________
CONFIDENTIALITY NOTICE: This email message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information or otherwise be protected by law. Any access, use, disclosure or distribution of this email message by anyone other than the intended recipient(s) is unauthorized and prohibited. If you are not an intended recipient (or an agent acting on an intended recipient's behalf), please contact the sender by reply email and immediately destroy all copies of the original message. Virus scanning is recommended on all email attachments.
Message 6 of 22
CCarreiras
Hi!
Sent to your email.
CCarreiras
Message 7 of 22
tcsteid
I have both Inventor Professional 2014 and 2015 loaded on my computer but I am not able to open the files. I get the message Error reading RSe stream. Any thoughts?
Message 8 of 22
CCarreiras
Hi!
Version 2015
Unzip the file in one folder.
Close all Inventor.
Inside the unziped folder, double click the project file:"Tubo_Curva_HVAC.ipj"
This will open Inventor.
Open the assembly:"Tubo_Curva_HVAC.iam"
Open iLogic Browser
In tab Forms, click the form button
Choose your values and apply
Save the assembly (in tab Manage, hit rebuild before) and close assembly
Open Drawing... and that's it.
If you have more problems, tell me.
CCarreiras
Message 9 of 22
dpottier
Hi I could use that parametric assembly. I am having trouble with an 8 inch to 6 inch reduction elbow.
Message 10 of 22
CCarreiras
in reply to: dpottier
HI!
And what's you question?
And whats your othetr parameters; diameter, curve radius, thickness... etc etc.
CCarreiras
Message 11 of 22
dpottier
Hi Carlos
Gracias for the reply.
Material -
0.25 inch black steel
All faces to be welded
Upper elbow radius - 8 inch (203.2 mm)
Lower elbow radius - 6 inch (152.4 mm)
I am not sure of the elbows radius from the junction of the XY axis. Possibly 8 inch if the height of the 8 inch part of the elbow was 11 inches above the XY axis ((d=8 + r=3) = 11) or 12 inches (see below from commercial reduction elbow)
This 8 inch to 6 inch reduction elbow should be commercially available but I need to get the data into an Inventor file.
Commercial 8 X 6 Centre to end = 12
Being able to change the diameters, example 8 inch to 6 or 10 inch upper and 4 or 8 inch lower would be a bonus.
The other end of the 6" pipe meets with an 8 inch square, 3/8 inch, box tube at bottom angle of 20 degrees right side of vertical.
Another issue will be a flange that will go from the 8 inch square tube to the 6 inch diameter pipe. Butt welding the pipe into the box tube would work but the transition from square to round woud be better with a flange.
Best regards
David
Ulaan Baatar, Mongolia
Message 12 of 22
tcsteid
I would be fine seeing an example using any sizes. I just want to learn how to create the elbow.
Message 13 of 22
dpottier
Have a look at this video
Message 14 of 22
Carlos, Would you mind sharing Your parametric assembly with me? I'm drawing an 90 degree reducing elbow going from 15" Diameter down to 7". Getting a 2d profile didn't take long but I'm having issues creating a 3D model. Your help would be very appreciated! Thanks, Travis
Message 15 of 22
IgorMir
Here it is. IV 2010 files.
Cheers,
Igor.
Web: www.meqc.com.au
Message 16 of 22
travis.turnbow25
in reply to: IgorMir
Thanks so much Igor, this worked wonderfully!
Message 17 of 22
IgorMir
in reply to: travis.turnbow25
You are welcome!
Message 18 of 22
kajobus
Good day
Will AutoDesk Inventor Sheet metal do a development like this ?
https://www.fastcam.com/fastshapes/layout-lobster-pattern-development-for-metal-fabrication.html
Reducing from inlet dia to outlet dia
Regards
Message 19 of 22
JDMather
in reply to: kajobus
@kajobus
Yes.
Message 20 of 22
kajobus
in reply to: JDMather
Hi , I has a quick look at your CADWhisperer youtube channel , impressive !
Do you have a video of a "Inventor sheet metal reducing elbow" similar to :
Regards
