Inventor General
Member
Message 1 of 8 (151 Views)
Inventor routing and tooling problems
151 Views, 7 Replies
10-03-2013 08:22 AM
I am doing a thesis on inventor Professional and the possibilties of using this programme with CNC machining. I have found certain add on packages to inventor that allow you to apply routing and tooling. I have access to inventor student 2014 and to inventor 2014 with an educational licence. I have tried to download and install these add ons to the student version but an error keeps arrising. I have access to the educational version too but I cannot use this licence unless I have gotten feedback that these add ons will work with this version as it is through the college I have access to it.
If someone could get back to me with some insight towards this post ASAP it would be much appreciated.
Message 2 of 8 (147 Views)
Re: Inventor routing and tooling problems
10-03-2013 08:38 AM in reply to: oisinbarrett
What are the urls to these add-on packages?
As you move forward on your Thesis you will want to be very very careful about providing complete and precise information when forming questions.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
mcgyvr
Message 3 of 8 (141 Views)
10-03-2013 08:50 AM in reply to: JDMather
voila.. you are just in time.. This was publically released this week. 100% Autodesk supported
http://cam.autodesk.com/
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Member
Message 4 of 8 (131 Views)
10-03-2013 09:41 AM in reply to: oisinbarrett
Thank you for your help. I have read through the information and it specifies inventor 2014, will this also work on the student or educational licence 2014 do you know?
Member
Message 5 of 8 (130 Views)
10-03-2013 09:43 AM in reply to: JDMather
Message 6 of 8 (122 Views)
10-03-2013 10:02 AM in reply to: oisinbarrett
oisinbarrett wrote:
... will this also work on the student or educational licence 2014 do you know?
There is no difference in functionality of the student or educational license.  The software is identical - only the license terms of use are different.  (not for profit - learning use)
I'll address the other problems in a few minutes.
Message 7 of 8 (110 Views)
10-03-2013 10:26 AM in reply to: oisinbarrett
This is not an add-in, it is a repair for existing functionality in Inventor (Professional - which you have) (old release).
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13855132&linkID=9242019
You do not need or want that.
To start Inventor Tooling go to your Templates and start a new Mold Design.iam file.
There are several tutorials (you will be prompted to run the tutorials.
Routed Systems in Inventor is piping/tubine and electrical wiring cable.
Go to Environments tab
So these are both areas of functionality that you already have in your student install of Inventor.
Neither of these are directly related to CNC machining (although tooling environment is used to create core/cavity mold designs).
It sounds like you need to investigate the CAM link suggested earlier.
mcgyvr
Message 8 of 8 (104 Views)
10-03-2013 10:41 AM in reply to: oisinbarrett
oisinbarrett wrote:
these are the urls i found. thank you for your advice.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13713884&linkID=9242019
 that is for Inventor 2010 and "tooling" in the Autodesk world is for injection molding design.. Not CNC fabrication which is what I assume you are talkinga bout.
Its a horrible name choice by Autodesk IMO..
Windows 7 64 bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
