Inventor General
Valued Contributor
Message 1 of 6 (818 Views)
Inventor project file structure
818 Views, 5 Replies
02-10-2012 08:31 AM
I am about to move my inventor files from D:\ to E:\, and I'm not going to change anything else, just simply the local hard drive, but this cause problem, all the work search pads needs to be modified manually from D:\xxxx to E:\xxxx,
is there any way around this to do it automatically?
Warm Regards
blair
Message 2 of 6 (796 Views)
Re: Inventor project file structure
02-10-2012 10:26 PM in reply to: 3DAli
You should only need to edit your Project File as long as you maintain the same directory structure in the new Drive. I do this all the time when the new release of IV comes out. All our work is done inside a main Project directory. I create a new main directory called TEST and copy all the sub-directories into it. Copy my existing Project file and edit the directories to point to the new TEST directory. Everything works fine.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Valued Contributor
Message 3 of 6 (780 Views)
02-11-2012 12:51 PM in reply to: 3DAli
Hi there,
thanks a lot for the input, ofcourse I figured my self this is the way to go, but imagine you are dealing with tons of project files (*.ipj), can you imagine how big of a deal it would be to edit them one by one, I have developed a tool "lil application" if you want to call it, so that it does it for me, but I'm wondering if IV provides you with something more professional or something for this kind of senarios.
Regards
Ali
Warm Regards
blair
Message 4 of 6 (777 Views)
02-11-2012 01:13 PM in reply to: 3DAli
I'm sure you could use write a Macro to do it, but suprisingly we don't have that many Project Files. All our stock manufactured items reside under a single Project file, all Customer or Custom work resides under another Project file and any of our our custom production equipment and jig/fixtures reside under a separate Project File.
I'm sure if we did a lot of custom customer work, we might have a separate Project file for each customer.
Win7-64
*Pro
sbixler
Message 5 of 6 (747 Views)
02-13-2012 04:38 AM in reply to: 3DAli
We have thousands of project files, since our projects are relatively small, and entirely self-contained.  They do not require any editing at all, no matter where they are used, because all the path references are relative to the .ipj file location.  The Workspace path is defined as ".", which means "right here where this file is".  All the other paths are defined relative to the Workspace, so they are completely portable.
If your project files have references to external libraries, Template locations or Design Data locations, then those paths would have to be edited for each project if they are relocated.  On the other hand, if they are referenced to a mapped drive letter, and the new location has the same mapping, then you're still good to go.
Valued Contributor
Message 6 of 6 (714 Views)
02-15-2012 07:29 AM in reply to: sbixler
No unfortunately my projects are not self contained, it means, I have to define search paths in defferent locations so that I could use those assemblies/parts,etc in my new project. for example, I have desined a base plate, it being filed under D:\Inventor\Projects\Base Plates\BP1 , the project file for this lives under D:\Inventor\Projects\Base Plates\BP.ipj
now, I have another project, let say "Post" that uses this base plate as well as bunch of other bits and pieces that are coming from other projects (due to being Generic). so I have defined workgroup search paths within my new project "i.e. Post"  that refers to D:\Inventor\Projects\Base Plates\. here enlies the problem, if I relocate D:\Inventor\xxxx to
E:\, the main workplace doesnt cause any issue since its defined relative, but all those workgroup search paths needs to be modified to "E:\Inventor\Projects\Base Plates\" for example. unless I dont know how to define them originally , so that they are relative to workspace.
I hope I made it clear enough this time, so any help is very much appreciated in advance.
P.S. my solution for this so far has been using a quick/search/repalce software to edit all *.ipj file and change "d:\" to "E:\" at push of a botton, thanks GOD that ipj files are text base and editable that way.
Cheers
Ali
Warm Regards
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
