Inventor Forum
Inventor parameter.value in cm instead of default units
0 REPLIES 0
Message 1 of 1
384 Views, 0 Replies
I am exporting many parameters to my skeleton model
If I export a parameter with value 1mm, the result is 0.1
I made a quickfix by making all my parameters unitless, but this is not how i would like it.
I am testing a bit in ilogic to fix this, because i want to use degrees and milimeters instead of unitless.
Dim oDoc As Document = ThisDoc.Document
Dim UserParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Dim UserParam As UserParameter
UserParams.AddByExpression("Testparam", "1", UnitsTypeEnum.kDefaultDisplayLengthUnits)
MsgBox(UserParams.Item("Testparam").Value)
My default length unit is 'mm' and 1 mm becomes 0.1mm when I sent it to my skeleton.
My question:
How can I make it possible that the parameter.Value = 1 regardless of wheter the parameter is mm, cm, inches or whatever?
Thanks in advance,
Arnold
0 REPLIES 0
